I just bought a MyBook Essential 2TB drive and started using it and working with it right away. Everything looked awesome and working, until i rebooted my computer, as it just won’t start.
It’s not a boot issue, as the Windows 7 startup begins, but then freezes on the loading image/animation. I disconnect, startup still frozen, so i restart the computer and i get the Windows start without any issues.
I’m also getting now, after some data was copied to the drive, the message from windows to “scan and fix MyBoot (E:)” when I always ejected/turned it off before disconnection. I tried once a quick scan to check, no issues found…
It’s all I’ve added to the system in the last 6 months, so I’m prtty sure it’s the drive itself. Any ideas on both issue?
