My Windows 10 PC will not boot if my 10 TB WD MyBook is attached (Model Number WDBBGB0100HBK-NESN, Part Number WDBBGB0100HBK-NA). If I disconnect the drive from the USB 3.0 port, the PC will boot. I can then reconnect the drive and access it through Windows Explorer. Is there a setting that needs to be changed on the drive or in Windows to allow the PC to bot with the drive attached? As I have been working remotely it is not convenient to drive to the office to manually reboot the PC.
Thank you!
