I have WD10TMVW-11ZSMS1 model 1 TB WD passport.
It has been used on same same PC and same position for a year.
I havent moved it or dropped it or done any kind of physical damage on it.
It is protected with UPS and external surge protection.
It has been attached to a powered usb hub.
Suddenly it stopped working and my PC (Win 10 x64) keeps trying to install “SATA Drivers” “Sata Bridge Drivers” randomly while the drive is connected.
I have 2 more WD passport devices and they are working just fine.
So I removed other USB drives and tried other USB 3.0 cables on it but it didnt work.
I gently removed the PCB Board and identified the part numbers.
Luckily I have found the PCB (WD10TMVW-11ZSMS1, 771737-B00 01P)
My question is: if the PCB is the problem, can it work with another identical PCB board ?
As I said, when I connect the drive, PC (win 10 x64) tries to install “Sata Drivers/ Bridge Drivers” but the harddrive doesn’t spin or making TIC TAC sounds ![]()
Thanks for your interest.
