Hi
Hi
WIll a WD mybook of 3tb or 4 tb in size work ok on windows 7 ?
I’m getting conflicting information off google.
I would like an upto date confirmation of the situation.
Could you also advise if :
The drive comes ready formated for use with windows 7 or will It need to be formated by me using GPT/GUID ?
WD support windows 7 users who buy an external drive over 2tb in size with firmwares or further information etc.
Any known issues and is the general advice not to use an external HDD over 2tb with windows or that it’s okay to do so.
thanks
twzz
