Which software should I use if I have more than one type of drive in the system?
Since the download pages asks you to put in your drive model to find the correct software, will there ever be a scenario where you have an older drive that calls for a different Data Lifeguard software version than a newer one? For example I still use PATA drives, but also have newer SATA ones.
Hello, Data Lifeguard software works with any hard drive model. For the specific software per model, you can check the download page, select the model and you will see all of the available software.
http://support.wdc.com/product/download.asp?lang=en
