Which passport do I have?
I have a red portable hard drive but can’t figure out the model. I’m looking for updates,etc.
Thanks,
Imma Dummy
Hi bzylzy,
You can check the Serial Number, printed on the back side of device under “S/N” and refer this link to check the Model Number and warranty details of your WD hard drive.
https://support.wdc.com/warranty/warrantystatus.aspx?lang=en
