Which 4TB Drive should I get
Looking at either 4TB My Passport, Elements, or My Book for backing up two home computers. Will be connecting it to a TP-Link C9 Router USB 3.0. Currently have a 1TB Seagate attached. Which WD would you recommend?
Thanks
I prefer to get the My Book Duo if you can. If not, get the single drive My Book is better then the Passport/Element.
I would suggest you to read this blog Buying a New Hard Drive: 7 Things You Must Know to know what things you should consider to buy the storage device.
