Is there a configuration file where My Passport stores settings, folders and files to backup?
Thank you!
Thank you!
The files and folders for the backup are stored on a folder called “WDSmartware.swstor”.
Thank you!
I’m sure WD Smartware (Not the Passport) has a configuration file for changing parameters, maybe a .INI file or something as plain as a text file with the configuration. It should be either on the installation folder for the program or the application data folder.
I haven’t found any configuration file up to now.
PS: I am waiting for an update for WD SmartWare. The current version 2.1.0 doesn’t save files and folders. Perhaps Western Digital has already recognized that WD SmartWare doesn’t back-up?
