When will WD Blue be updated to 96L BiCS4 or 112L BiCS5 3D TLC?
tl;dr It has been over 2.5 years since WD Blue was last updated and many other brands have introduced their 96L 3D NAND products (some of them based on WD’s own BiCS4) so when can we expect WD Blue series to get updated? When can we see WDS500G3B0A in the market?
Some history:
2.5" WD Blue SATA was launched with planar TLC NAND in 2016. The product #s were like WDS500G1B0A.
In May 2017 the shift to 64L 3D TLC was announced and full availability followed soon. The product numbers are like WDS500G2B0A. Th new products had better performance and slightly lower power consumption.
Just a month after the launch of BiCS3 64L 3D NAND drives, in June 2017 WD announced their 96L BiCS4 3D TLC NAND. But now it has been over 2 years without an upgrade. Customers who are in the shops in 2020 are still buying technology from early 2017, not to mention the newer 96L BiCS4 technology under discussion is also from 2017.
Will WD soon offer an update (just the way they did from 2016 to 2017)?
Why not directly jump to their 112L BiCS5 TLC they announced just last week?
WD had launched SN550 which uses BiCS4:
It was an upgrade to the SN500 which used BiCS3.
Some people are having problems with new 2.5" WD Blue SATA drives:
https://www.reddit.com/r/techsupport/comments/hkqvkf/installed_a_western_digital_ssd_but_it_shows_as_a/
https://community.wd.com/t/wd-ssd-blue-1-tb-mislabeled-as-sandisk-g5-bics4/254903
https://hardforum.com/threads/2-different-versions-of-wd-blue-3d-2-5-ssd-drives-one-is-significantly-slower-beware.1996492/post-1044666121
Also
The problem is also cropping up on WD Blue 3D NAND 2TB Internal SSD - M.2 2280 SSD - Newegg.com, WD Blue 3D NAND 250GB Internal SSD - SATA III 6Gb/s 2.5"/7mm Solid State Drive - WDS250G2B0A - Newegg.com and Solved: Re: Does HP Pavilion p003-tx notebook support both SSD & PCI... - Page 2 - HP Support Community - 7666078; in non-English speaking Western Digital WD Blue 3D SSD (500GB) : 다나와 가격비교, https://www.citilink.ru/catalog/computers_and_notebooks/hdd/ssd_in/1015925/vopros-otvet/, Western Digital WD Blue 3D SSD (1TB) : 다나와 가격비교, https://www.citilink.ru/catalog/computers_and_notebooks/hdd/ssd_in/1015927/vopros-otvet/
Why’s the mix-up? Why the switch to BiCS4 without changing the model number and in the process even mixing it up with their SanDisk lineup (btw SanDisk doesn’t even sell anything by called SanDisk G5 and it isn’t there on UserBenchmark but here PassMark - SanDisk SSD G5 BICS4 - Price performance comparison and here Novabench - SanDisk SSD G5 BICS4 - Storage Performance)?
Buyers in the market for a new or old WD Blue, will never know what to expect … 64L or 96L.
This isn’t happening with the NVMe WD Blue drives - there’s clear distinction of SN500 vs SN550.
With this going on even the question arises whether the newer technologies should be anticipated? Or the company themselves feel the power and performance difference is not enough to warrant a model number change? WD has not yet upgraded their Black line of upscale SSDs, what does it say about the newer technology. Should it be anticipated eagerly or mostly it will be the same or a step backwards?
P.S: Two more links from the same thread:
Despite BiCS4 being better https://hardforum.com/threads/2-different-versions-of-wd-blue-3d-2-5-ssd-drives-one-is-significantly-slower-beware.1996492/post-1044667618 the WD Blue 2.5" SATA drives using it doesn’t seem to perform better than the old one https://hardforum.com/threads/2-different-versions-of-wd-blue-3d-2-5-ssd-drives-one-is-significantly-slower-beware.1996492/post-1044683065/ whereas the SN550 NVMe is in many metrics better than SN500.
Unfortunately 2.5" WD Blue was one of the best value options on the market for the millions of slightly older systems which do not have NVMe. Looks like buyers should go elsewhere ~ buying something that is a step backwards from a 2017 product doesn’t seem feasible in 2020.
162L BiCS6 announced exactly a week ago (Kioxia and Western Digital Announce 6th-Generation 3D Flash Memory | Western Digital) received coverage from tech press who expect that products based on this tech will be in the shops in 21H2.
Why is it always said that SATA interface is overwhelmed by modern SSDs even though only the first few seconds of file-copying are @ 500+ MB/s, the speed generally reduces to 200-250 MB/s after just a few seconds?
A controller upgrade should also come! Not for speed, but for latency … and the lower power consumption of a new manufacturing process (12/7/5 nm) will help battery life.
There’s lots of 2.5" SATA customers still around and 4 years is time enough to revamp the product in a big way.
Update 26th Feb 2023: Western Digital revenue misery continues – Blocks and Files This document notes that still the BiCS5 is used the most and BiCS8 is maturing ahead of time, maybe there will be direct jump from BiCS5 to BiCS8 as far as market products are concerned.
It has been on the market for some time now: 250GB WD Blue SA510 SATA SSD 2.5”/7mm Cased | SanDisk
Apparently the 250GB, 500GB and 1TB versions are branded as SA510 and have the “3” in the model # whereas the larger 2TB & 4TB versions still have the “2” https://www.westerndigital.com/products/internal-drives/wd-blue-sata-2-5-ssd#WDS200T2B0A although the 3D NAND written clearly on the sticker (in 2020) doesn’t seem to be present anymore.
TechPowerUp tells the launch date 31st May 2022, and also that the NAND is BiCS5:
Other related links:
https://www.reddit.com/r/pcmasterrace/comments/wk6myd/wd_blue_sa510_vs_3d_nand_sata_3/
https://www.reddit.com/r/NewMaxx/comments/z5kdsc/wd_blue_sa510/
There’s limited information about SA510. Some have speculated (see above links) that it is a DRAMless configuration. This brings it parallel to the NVMe series in WD product range, where Green = QLC, Blue = DRAMless and WD_BLACK = DRAM.
The previous distinction in 2.5" range was Blue = DRAM & Green = DRAMless, now if the Blue (SA510) = DRAMless, then what is the difference now?
More guessing: Blue = DRAMless 3D TLC, Green = DRAMless QLC! Can anybody please confirm?
8th generation BiCS announced 31 March 2023!
BiCS8 is nearly ready for market.
It will come in both options: TLC & QLC.
I last grabbed an SN580 M.2 NVMe SSD 2TB which seems to be a fair SSD with TLC NAND which gives it excellent endurance ratings vs QLC NAND
I noticed more recently a SN5000 SSD is now availale at 4TB but I am seeing TLC 112 layer NAND in my table
