File Shredder - Currently, if you add a file into the vault, it’s pointless. The original file on the flash drive is not removed. You have to manually delete it. What the heck is this!? the file can still be retreived with some file recovery software. What we need is a file shredder to securely remove the file.
Not completely encrypted - your files are still visible in a way. In the vault folder, the files are still there with labels starting at 0000. if someone didn’t care about reading your files, but just screwing you up, they can easily delete those files.
SLOW - it takes ages. too so long for just 1GB.
share what you find SecureAccess is missing.
