I have problems with WD2Go, while I’m trying to access my MBL through the service.
I think everything is properly set up on the device. I can log into WD2Go on a remote computer and then I’m able to connect to a share on the device to open it in explorer. I can browse the folders/files, everything seems to be OK.
Until I try to copy some files/folders to the local disk. For some files, I get the error message “Can’t read from source file or disk.” As I tested this, it does not depend on the file size (I’m working with 100-400KB files), or file type, or anything I can think of. There are just some files I can copy without any problem and some others I can’t. Disconnect and reconnect, the very same files I cannot copy.
Can anyone help me?
PS: I have 2TB MBL with latest firmware, trying to connect to it from Win7/Win8 machines.
