WD Sync, how to resync?
Hello all. I was using WD Sync succesfully by syncing desktop and documents folders. I had to format the C drive and reinstalled windows from zero. Now I wonder If I can get sync’ed files bak to their original folders (or somewhere else I can reach) ?
Regards,
If you wish to copy your files from the My Cloud back to your computer you will have to do it manually.
WD Sync does not have the option to do this.
Hello and thank you for the answer. I would like to do it manually, but, where the sync’ed files are, in the Mycloud drive???
