Is there anywhere where I can change WD Syncs version history. I am trying to build apps using Visual Studio the only issue is any changes I make will create the same file with the timestamp. Great for normal files but it’s ruining my apps and it’s annoying constantly having to remove duplicates.
I don’t want to have to take my apps off WD Sync as it’s one of the main reasons I got the cloud in the first place. If there isn’t away any chances of an update?
Any better 3rd Party Apps replaced WD Sync yet?
