Good afternoon,
I have a WD hard drive that had a wrong power adapter connected, which caused a short circuit in the SATA to USB PCB
the hard drive itself is still turning, but is showing up as not intialized in Disk Manager.
pics of the burned PCB:
the data itself does need to be recovered in one way or another, since the end user used it as storage, rather then an actual backup
The hard drive i a WD Mybook Essentials USB3.0
PN: WDBACW0010HBK-01
the hard drive itself is a WD smartware product, but neither the smartware software or the password protection was used.
hence i thought with abit of luck i could just read the data if i connect it to a PC, unfortunatly the drive came up as not initialized
any tips or guidelines any of you could forward me too?
thank you for your time,
Signed, Sven
