WD passport mac
I bought my 1tb passport and use it on my mac when i was putting some tv shows on it i realized that it filled up to quickly. It says avialible capacity 62gb when i click on get info. Any solutions?
Hi, the question would be how many GB of files did you transfer to it? You can also check the disk utility to see if you have unpartitioned space available.
Turns out i partitioned it for 62gb easy fix thanks.
