I formatted my drive using disk utility but after it was complete the drive split into two separate 2TB drives with no root drive for a partition. Has anyone had this before and were you able to get the two drives together again ?
![56|654x499]Hi JS-NathanB,
Maybe you should try contacting WD’s Technical Support about this.
The link below will allow you to call support.
