Hey,
My 1 Tb My Passport WD external drive does not show up in my computer. I have tried different computers but the result is the same. It does show up in device manager and computer manager - Storage devices (where in it displays that the drive is not initiated). Also I am able to safely eject the HDD, ie the Safely remove option for the HDD shows up. Still I cannot see the HDD in My Computer. Also, the HDD blinks and makes small beeping sounds. Please suggest what should I do. Thank you.
Make sure that you test the drive on the back usb ports of a desktop computer and try with a different USB cable, if stills the same after those steps, you may try to recover your files with a data recovery software.
If you don’t have any files on the drive, through the disk management, you will be able to initialize the drive and create a new partition on the drive.
Check the link below.
How to initialize or write a signature to a secondary hard drive or Solid State drive in Windows (8, 7, Vista, XP)
