Hi Everyone,
I’ve been desperately scanning for a solution for my problem and I can’t seem to find a thread that has come up with anything I can work with. I have been happily using my external hard drive for over a year now and there have never been any problems with it whatsoever, until today.
Here is the current state of my hard drive:
Turns on with only the power connected. (USB port connection not anymore necessary)
LED Light turns on and stays on.
I can hear the HDD drive inside moving but after 10-15 seconds it just stops.
Can’t be detected by any device. Nothings happens when I connect the hard drive to devices I used to connect it to. (Laptop/PC/TV)
That being said, here are the series of events that led me to realize that I have a problem with my external drive:
Went to sleep last night with a video stored on my external drive playing on my laptop. The drive worked without a hitch. The drive was detected and was able to play the video file just like any other day.
Woke up this morning and decided I’d finish the video I was watching before fell asleep, realized that for some reason the drive was not anymore detected by my computer.
I figured that it must be some kind of connection problem that got loose during the night, but after checking all connections the drive was still not detected by my computer.
Through the process of checking all my wires, I realized that for some reason the drive turns on even though it is only connected to the power. It used to be that it would only turn on if I connect it to both the power and the usb port.
Tried the following things with no luck:
Used a different power cable with the same 12V and 1.5A ratings.
Used a different usb cable from my other WD HDD.
Used different usb ports. (all three ports from two different laptops, one of which is a 3.0 usb port and another USB port from my flatscreen)
A process that was said to “reset” the board of the My Book (involves taking out all the wires. plugging in the usb port first in a pc that is off. turning on the pc. then finally plugging in the power of the my book)
Really hoping someone here can help me as I desperately need this drive to work again ASAP. Thanks in advance to any help that is offered!
