Hopefully a simple question - has anyone found a supplier for replacement USB 3.0 cables? The cable bundled with my disk is impracticably short at about one metre (I need approximately 2 metres). I’m in the UK.
You can check with customer service but I vaguely remember something about it being a proprietary cable.
Joe
If you check with customer service ask for Model: WDCA042RNN
Free if your under warranty just one though after that its $14.99 its about 2 feet but currently out of stock I’ll keep you updated on when they come in
Thank you both. Proprietary cable? Pah!! ![]()
