Have bought brand new WD my passport Ultra 1TB and it doesn’t show up on my computer has not installation or beginning process. Is it faulty or is this a problem that can be fixed here?
You should try some basic troubleshooting:
1- Disconnect the drive from the computer and restart the computer.
2- If the computer is a desktop, connect it on the back USB port (directly to the PC, not through a hub).
3- Make sure you hear the connection sound windows makes when recognizes a USB device.
4- Go to "Disk Management” to verify if the drive shows up there.
If the drive shows up in disk management but it is not seen on Computer, then it means the partition is corrupted and you will have to format it in order to use it again. Please note that formatting the drive will delete all data stored on it.
