WD Elements Questions
I am using wd elements 1 tb portable HDD. I want to set a password on the HDD, but I can not find the software. Is there any software you can recommend? Thanks.
The WD Elemetns drive does not include any software. If you want to set a password on your drive I recommend a 3rd party software. Try doing a google search for a 3rd party security software.
