WD Elements Portable 500GB is seen by my PC when i use the WD drive formater but it does not apear in my computer menu, when i try to use the formater to format it says the drive is either too small or is not compatible with the version of the formater. HELP HELP HELP Please
Maybe this will help http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=3865 In case you missed a step. Formatting is not something most of us do very often. A third party tool may be easier also http://www.partitionwizard.com/
Joe
