hello, i wanna learn about this product
“WD Elements 6TB 3.5” USB 3.0 WDBWLG0060HBK-EESN" in this one can we separate the disc from the case without problem? i heard in some products inside the case e-sata and ubs stick together ? i have a diskstation, i wanna use as internal later can you help me pls?
Thank you for your help…
You won’t get any ‘official’ help with shucking (as it’s known) a WD hard drive as it voids all warranty doing so… you’ll find more info elsewhere
example: https://www.reddit.com/r/DataHoarder/comments/a8sf1h/wd_elements_6tb_shucking/
Thank you for your help my friend.
But as result no1 buy and try with 6tb elements shucking and talking about too much staff about hdd colors that i didnt understand. If you have better explanation or knowledge for me pls write me back.
I don’t shuck external hard drives so i can’t help sorry ![]()
If no1 has buy and try with 6tb elements … then i guess it’s your decision whether to take a gamble.
If you’re at a water pool and ask if the water is cold, and no-one responds with a definite answer … then, the only way to know is to test it for yourself.
