My 3TB Elements suddenly not working on my Mac. The power is always connected to ups, and the usb cable only connected to PC when needed. Normally the Elements led light turn on (and blinking) only when we plug the USB cable to the computer, but this time it’s always on when I turn on the ups. But when I connect the usb cable to pc nothing is happen. The led is not blinking, the Elements is not showing on Disk Utility either. I’ve tried on every usb port and in my macbook pro with same result. Any thought?
Whenever you connect an external drive to your mac, the storage drive may not show up on Desktop, Finder or even on Disk Utility due to various reasons:
USB connectivity problem
MacOS preference settings
Partition map damage
Device incompatibility
Physical damage on a drive
However, to fix the issue, you can try the below methods:
Check the USB connectivity
Enable visibility of external hard drive
Update macOS
Repair external hard drive by using Disk Utility
Repair external hard drive by using Terminal
Erase the external hard drive
If none of the above works, then the drive needs replacement
Further, you can also check the below link for steps to be followed in each method mentioned above:
