WD Elements 1.5 TB - SHould i remove cable for night?
Hello
After i shutdown PC, should i remove USB cable that connect WD Elements to PC, or HDD wont work after PC is off?
If the computer is off then there should be no power going to the USB ports. This means the drive should also turn off. Either way having the drive on all the time should not be a problem either.
