WD easystore won't power up
I went to use my WD easystore (WDBCKA0080HBK-NA) the other day and it would not power up. No signs of life. It sits on my desk with the power disconnected and I only power it up when I need to store/retrieve data. I checked the incoming power and I have 12v coming from the cord. Shouldn’t the drive spin up even if I don’t have the USB connected? I need to be able to get the data off the internal drive.
Thanks,
George
We recommend you run diagnostics on the drive by following the steps mentioned in the link: How to Install and Use WD Security and WD Drive Utilities Features
My WD Easystore won’t power up either. This link takes me to the main information page. Is there another link I could try?
