WD Discovery noticed to me about new version software and I choiced upgrade but after restart windows WD Discovery did not completed installation gave me setup failed error message with
I tried so many time to setup but always failed. Please Help me because I could not usinf my my cloude home device.
Thank you very much
=== Verbose logging started: 13.05.2020 05:47:47 Build type: SHIP UNICODE 5.00.10011.00 Calling process: C:\Users\MURATL~1\AppData\Local\Temp{9795CC9E-C430-4F43-AE18-E51C46DBFCE4}.be\WD_KDA_Setup.exe ===
MSI (c) (54:68) [05:47:47:868]: Resetting cached policy values
MSI (c) (54:68) [05:47:47:868]: Machine policy value ‘Debug’ is 0
MSI (c) (54:68) [05:47:47:868]: ******* RunEngine:
******* Product: C:\ProgramData\Package Cache{CA7F7232-526E-41BD-971A-47BE28C18516}v2.1.0.311\KDA_Installer.msi
******* Action:
******* CommandLine: **********
MSI (c) (54:68) [05:47:47:869]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (54:68) [05:47:47:869]: Grabbed execution mutex.
MSI (c) (54:68) [05:47:47:888]: Cloaking enabled.
MSI (c) (54:68) [05:47:47:888]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (54:68) [05:47:47:892]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (88:00) [05:47:47:903]: Running installation inside multi-package transaction C:\ProgramData\Package Cache{CA7F7232-526E-41BD-971A-47BE28C18516}v2.1.0.311\KDA_Installer.msi
MSI (s) (88:00) [05:47:47:903]: Grabbed execution mutex.
MSI (s) (88:78) [05:47:47:906]: Resetting cached policy values
MSI (s) (88:78) [05:47:47:906]: Machine policy value ‘Debug’ is 0
MSI (s) (88:78) [05:47:47:906]: ******* RunEngine:
******* Action:
MSI (s) (88:78) [05:47:47:932]: Machine policy value ‘DisableUserInstalls’ is 0
MSI (s) (88:78) [05:47:47:944]: Note: 1: 2203 2: C:\WINDOWS\Installer\inprogressinstallinfo.ipi 3: -2147287038
MSI (s) (88:78) [05:47:47:947]: SRSetRestorePoint skipped for this transaction.
MSI (s) (88:78) [05:47:47:957]: File will have security applied from OpCode.
MSI (s) (88:78) [05:47:48:179]: SOFTWARE RESTRICTION POLICY: Verifying package → ‘C:\ProgramData\Package Cache{CA7F7232-526E-41BD-971A-47BE28C18516}v2.1.0.311\KDA_Installer.msi’ against software restriction policy
MSI (s) (88:78) [05:47:48:180]: SOFTWARE RESTRICTION POLICY: C:\ProgramData\Package Cache{CA7F7232-526E-41BD-971A-47BE28C18516}v2.1.0.311\KDA_Installer.msi has a digital signature
MSI (s) (88:78) [05:47:48:353]: SOFTWARE RESTRICTION POLICY: C:\ProgramData\Package Cache{CA7F7232-526E-41BD-971A-47BE28C18516}v2.1.0.311\KDA_Installer.msi is permitted to run at the ‘unrestricted’ authorization level.
MSI (s) (88:78) [05:47:48:353]: MSCOREE not loaded loading copy from system32
MSI (s) (88:78) [05:47:48:364]: End dialog not enabled
MSI (s) (88:78) [05:47:48:365]: Original package ==> C:\ProgramData\Package Cache{CA7F7232-526E-41BD-971A-47BE28C18516}v2.1.0.311\KDA_Installer.msi
MSI (s) (88:78) [05:47:48:365]: Package we’re running from ==> C:\WINDOWS\Installer\5090e99.msi
MSI (s) (88:78) [05:47:48:368]: APPCOMPAT: Compatibility mode property overrides found.
MSI (s) (88:78) [05:47:48:370]: APPCOMPAT: looking for appcompat database entry with ProductCode ‘{CA7F7232-526E-41BD-971A-47BE28C18516}’.
MSI (s) (88:78) [05:47:48:370]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (88:78) [05:47:48:414]: Machine policy value ‘TransformsSecure’ is 0
MSI (s) (88:78) [05:47:48:414]: User policy value ‘TransformsAtSource’ is 0
MSI (s) (88:78) [05:47:48:414]: Machine policy value ‘DisablePatch’ is 0
MSI (s) (88:78) [05:47:48:414]: Machine policy value ‘AllowLockdownPatch’ is 0
MSI (s) (88:78) [05:47:48:414]: Machine policy value ‘DisableLUAPatching’ is 0
MSI (s) (88:78) [05:47:48:415]: Machine policy value ‘DisableFlyWeightPatching’ is 0
MSI (s) (88:78) [05:47:48:417]: APPCOMPAT: looking for appcompat database entry with ProductCode ‘{CA7F7232-526E-41BD-971A-47BE28C18516}’.
MSI (s) (88:78) [05:47:48:417]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (88:78) [05:47:48:417]: Transforms are not secure.
MSI (s) (88:78) [05:47:48:417]: Note: 1: 2205 2: 3: Control
MSI (s) (88:78) [05:47:48:417]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is ‘C:\Users\MURATL~1\AppData\Local\Temp\WD_Desktop_App_2.1.0.311_20200513054742_002_KDA_Installer.msi.log’.
MSI (s) (88:78) [05:47:48:417]: Command Line: ARPSYSTEMCOMPONENT=1 MSIFASTINSTALL=7 MSIUNINSTALLSUPERSEDEDCOMPONENTS=1 INSTALLDIR=C:\Program Files\WD Desktop App NORMALINSTALL=0 REBOOT=ReallySuppress CURRENTDIRECTORY=C:\Users\Murat LOKMANOĞLU\AppData\Local\Temp\WDDiscoveryInstaller\WD_Discovery_637249456103678672 CLIENTUILEVEL=3 MSICLIENTUSESEXTERNALUI=1 CLIENTPROCESSID=13908
MSI (s) (88:78) [05:47:48:417]: PROPERTY CHANGE: Adding PackageCode property. Its value is ‘{DDB8A7B5-C10C-46D2-A040-830A1A96D122}’.
MSI (s) (88:78) [05:47:48:417]: Product Code passed to Engine.Initialize: ‘’
MSI (s) (88:78) [05:47:48:417]: Product Code from property table before transforms: ‘{CA7F7232-526E-41BD-971A-47BE28C18516}’
MSI (s) (88:78) [05:47:48:417]: Product Code from property table after transforms: ‘{CA7F7232-526E-41BD-971A-47BE28C18516}’
MSI (s) (88:78) [05:47:48:417]: Product not registered: beginning first-time install
MSI (s) (88:78) [05:47:48:418]: Product {CA7F7232-526E-41BD-971A-47BE28C18516} is not managed.
MSI (s) (88:78) [05:47:48:418]: MSI_LUA: Credential prompt not required, user is an admin
MSI (s) (88:78) [05:47:48:418]: PROPERTY CHANGE: Adding ProductState property. Its value is ‘-1’.
MSI (s) (88:78) [05:47:48:418]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (s) (88:78) [05:47:48:418]: User policy value ‘SearchOrder’ is ‘nmu’
MSI (s) (88:78) [05:47:48:419]: Adding new sources is allowed.
MSI (s) (88:78) [05:47:48:419]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is ‘1’.
MSI (s) (88:78) [05:47:48:419]: Package name extracted from package path: ‘KDA_Installer.msi’
MSI (s) (88:78) [05:47:48:420]: Package to be registered: ‘KDA_Installer.msi’
MSI (s) (88:78) [05:47:48:420]: Note: 1: 2205 2: 3: Error
MSI (s) (88:78) [05:47:48:424]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (s) (88:78) [05:47:48:424]: Machine policy value ‘DisableMsi’ is 0
MSI (s) (88:78) [05:47:48:424]: Machine policy value ‘AlwaysInstallElevated’ is 0
MSI (s) (88:78) [05:47:48:424]: User policy value ‘AlwaysInstallElevated’ is 0
MSI (s) (88:78) [05:47:48:424]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI (s) (88:78) [05:47:48:424]: Running product ‘{CA7F7232-526E-41BD-971A-47BE28C18516}’ with elevated privileges: Product is assigned.
MSI (s) (88:78) [05:47:48:424]: PROPERTY CHANGE: Adding ARPSYSTEMCOMPONENT property. Its value is ‘1’.
MSI (s) (88:78) [05:47:48:424]: PROPERTY CHANGE: Adding MSIFASTINSTALL property. Its value is ‘7’.
MSI (s) (88:78) [05:47:48:424]: PROPERTY CHANGE: Adding MSIUNINSTALLSUPERSEDEDCOMPONENTS property. Its value is ‘1’.
MSI (s) (88:78) [05:47:48:424]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is ‘C:\Program Files\WD Desktop App’.
MSI (s) (88:78) [05:47:48:424]: PROPERTY CHANGE: Adding NORMALINSTALL property. Its value is ‘0’.
MSI (s) (88:78) [05:47:48:424]: PROPERTY CHANGE: Adding REBOOT property. Its value is ‘ReallySuppress’.
MSI (s) (88:78) [05:47:48:424]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is ‘C:\Users\Murat LOKMANOĞLU\AppData\Local\Temp\WDDiscoveryInstaller\WD_Discovery_637249456103678672’.
MSI (s) (88:78) [05:47:48:424]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is ‘3’.
MSI (s) (88:78) [05:47:48:424]: PROPERTY CHANGE: Adding MSICLIENTUSESEXTERNALUI property. Its value is ‘1’.
MSI (s) (88:78) [05:47:48:424]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is ‘13908’.
MSI (s) (88:78) [05:47:48:424]: Machine policy value ‘DisableAutomaticApplicationShutdown’ is 0
MSI (s) (88:78) [05:47:48:424]: RESTART MANAGER: Disabled by MSIRESTARTMANAGERCONTROL property; Windows Installer will use the built-in FilesInUse functionality.
MSI (s) (88:78) [05:47:48:424]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is ‘1’.
MSI (s) (88:78) [05:47:48:424]: TRANSFORMS property is now:
MSI (s) (88:78) [05:47:48:424]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is ‘500’.
MSI (s) (88:78) [05:47:48:429]: SHELL32::SHGetFolderPath returned: C:\Users\Murat LOKMANOĞLU\AppData\Roaming
MSI (s) (88:78) [05:47:48:433]: SHELL32::SHGetFolderPath returned: C:\Users\Murat LOKMANOĞLU\Favorites
MSI (s) (88:78) [05:47:48:436]: SHELL32::SHGetFolderPath returned: C:\Users\Murat LOKMANOĞLU\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (s) (88:78) [05:47:48:440]: SHELL32::SHGetFolderPath returned: C:\Users\Murat LOKMANOĞLU\Documents
MSI (s) (88:78) [05:47:48:445]: SHELL32::SHGetFolderPath returned: C:\Users\Murat LOKMANOĞLU\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (s) (88:78) [05:47:48:449]: SHELL32::SHGetFolderPath returned: C:\Users\Murat LOKMANOĞLU\AppData\Roaming\Microsoft\Windows\Recent
MSI (s) (88:78) [05:47:48:453]: SHELL32::SHGetFolderPath returned: C:\Users\Murat LOKMANOĞLU\AppData\Roaming\Microsoft\Windows\SendTo
MSI (s) (88:78) [05:47:48:457]: SHELL32::SHGetFolderPath returned: C:\Users\Murat LOKMANOĞLU\AppData\Roaming\Microsoft\Windows\Templates
MSI (s) (88:78) [05:47:48:457]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (s) (88:78) [05:47:48:461]: SHELL32::SHGetFolderPath returned: C:\Users\Murat LOKMANOĞLU\AppData\Local
MSI (s) (88:78) [05:47:48:464]: SHELL32::SHGetFolderPath returned: C:\Users\Murat LOKMANOĞLU\Pictures
MSI (s) (88:78) [05:47:48:472]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (88:78) [05:47:48:476]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (88:78) [05:47:48:479]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs
MSI (s) (88:78) [05:47:48:483]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu
MSI (s) (88:78) [05:47:48:487]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (s) (88:78) [05:47:48:495]: SHELL32::SHGetFolderPath returned: C:\Users\Murat LOKMANOĞLU\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (88:78) [05:47:48:499]: SHELL32::SHGetFolderPath returned: C:\Users\Murat LOKMANOĞLU\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (88:78) [05:47:48:502]: SHELL32::SHGetFolderPath returned: C:\Users\Murat LOKMANOĞLU\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
MSI (s) (88:78) [05:47:48:506]: SHELL32::SHGetFolderPath returned: C:\Users\Murat LOKMANOĞLU\AppData\Roaming\Microsoft\Windows\Start Menu
MSI (s) (88:78) [05:47:48:510]: SHELL32::SHGetFolderPath returned: C:\Users\Murat LOKMANOĞLU\Desktop
MSI (s) (88:78) [05:47:48:515]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (s) (88:78) [05:47:48:515]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
MSI (s) (88:78) [05:47:48:516]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (s) (88:78) [05:47:48:553]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (s) (88:78) [05:47:48:553]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is ‘1’.
MSI (s) (88:78) [05:47:48:553]: PROPERTY CHANGE: Adding Privileged property. Its value is ‘1’.
MSI (s) (88:78) [05:47:48:553]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (s) (88:78) [05:47:48:554]: PROPERTY CHANGE: Adding USERNAME property. Its value is ‘Windows Kullanıcısı’.
MSI (s) (88:78) [05:47:48:554]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (s) (88:78) [05:47:48:554]: PROPERTY CHANGE: Adding DATABASE property. Its value is ‘C:\WINDOWS\Installer\5090e99.msi’.
MSI (s) (88:78) [05:47:48:554]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is ‘C:\ProgramData\Package Cache{CA7F7232-526E-41BD-971A-47BE28C18516}v2.1.0.311\KDA_Installer.msi’.
MSI (s) (88:78) [05:47:48:554]: Machine policy value ‘MsiDisableEmbeddedUI’ is 0
MSI (s) (88:78) [05:47:48:554]: EEUI - Disabling MsiEmbeddedUI due to existing external or embedded UI
MSI (s) (88:78) [05:47:48:554]: EEUI - Disabling MsiEmbeddedUI for service because it’s not a quiet/basic install
MSI (s) (88:78) [05:47:48:555]: Note: 1: 2205 2: 3: PatchPackage
MSI (s) (88:78) [05:47:48:555]: Machine policy value ‘DisableRollback’ is 0
MSI (s) (88:78) [05:47:48:555]: User policy value ‘DisableRollback’ is 0
MSI (s) (88:78) [05:47:48:555]: PROPERTY CHANGE: Adding UILevel property. Its value is ‘2’.
MSI (s) (88:78) [05:47:48:555]: PROPERTY CHANGE: Adding MsiUISourceResOnly property. Its value is ‘1’.
=== Logging started: 13.05.2020 05:47:48 ===
MSI (s) (88:78) [05:47:48:557]: Note: 1: 2203 2: C:\WINDOWS\Installer\inprogressinstallinfo.ipi 3: -2147287038
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is ‘603’. Its new value: ‘601’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is ‘603’. Its new value: ‘601’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘0’. Its new value: ‘14’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘14’. Its new value: ‘13’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘13’. Its new value: ‘12’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘12’. Its new value: ‘11’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘11’. Its new value: ‘10’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘10’. Its new value: ‘9’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘9’. Its new value: ‘8’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘8’. Its new value: ‘7’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘7’. Its new value: ‘6’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘6’. Its new value: ‘5’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘5’. Its new value: ‘4’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘4’. Its new value: ‘3’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘3’. Its new value: ‘2’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘2’. Its new value: ‘1’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘1’. Its new value: ‘0’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is ‘601’. Its new value: ‘600’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is ‘601’. Its new value: ‘600’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is ‘600’. Its new value: ‘502’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is ‘600’. Its new value: ‘502’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is ‘502’. Its new value: ‘501’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is ‘502’. Its new value: ‘501’.
MSI (s) (88:78) [05:47:48:557]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is ‘501’. Its new value: ‘500’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is ‘501’. Its new value: ‘500’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘0’. Its new value: ‘14’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘14’. Its new value: ‘13’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘13’. Its new value: ‘12’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘12’. Its new value: ‘11’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘11’. Its new value: ‘10’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘10’. Its new value: ‘9’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘9’. Its new value: ‘8’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘8’. Its new value: ‘7’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘7’. Its new value: ‘6’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘6’. Its new value: ‘5’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘5’. Its new value: ‘4’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘4’. Its new value: ‘3’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘3’. Its new value: ‘2’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘2’. Its new value: ‘1’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is ‘1’. Its new value: ‘0’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is ‘500’. Its new value: ‘400’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is ‘500’. Its new value: ‘400’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is ‘400’. Its new value: ‘603’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is ‘400’. Its new value: ‘603’.
MSI (s) (88:78) [05:47:48:558]: PROPERTY CHANGE: Adding ACTION property. Its value is ‘INSTALL’.
MSI (s) (88:78) [05:47:48:558]: Doing action: INSTALL
MSI (s) (88:78) [05:47:48:558]: Note: 1: 2205 2: 3: ActionText
Action start 05:47:48: INSTALL.
MSI (s) (88:78) [05:47:48:559]: Running ExecuteSequence
MSI (s) (88:78) [05:47:48:559]: Doing action: FindRelatedProducts
MSI (s) (88:78) [05:47:48:560]: Note: 1: 2205 2: 3: ActionText
Action start 05:47:48: FindRelatedProducts.
MSI (s) (88:78) [05:47:48:562]: Doing action: AppSearch
MSI (s) (88:78) [05:47:48:562]: Note: 1: 2205 2: 3: ActionText
Action ended 05:47:48: FindRelatedProducts. Return value 1.
Action start 05:47:48: AppSearch.
MSI (s) (88:78) [05:47:48:565]: Note: 1: 1322 2:
MSI (s) (88:78) [05:47:48:567]: Note: 1: 1325 2: wdfsconnect2017.sys
MSI (s) (88:78) [05:47:48:567]: Note: 1: 1322 2:
MSI (s) (88:78) [05:47:48:569]: Note: 1: 1325 2: wdfsconnect2017.sys_
MSI (s) (88:78) [05:47:48:569]: PROPERTY CHANGE: Adding WDFS_DRIVER_FOUND property. Its value is ‘C:\WINDOWS\System32\drivers\wdfsconnect2017.sys_’.
MSI (s) (88:78) [05:47:48:570]: Note: 1: 1322 2:
MSI (s) (88:78) [05:47:48:571]: Note: 1: 1325 2: WDFSConnectMntNtf2017.dll_
MSI (s) (88:78) [05:47:48:573]: Note: 1: 1322 2:
MSI (s) (88:78) [05:47:48:574]: Note: 1: 1325 2: WDFSConnectNetRdr2017.dll_
MSI (s) (88:78) [05:47:48:575]: PROPERTY CHANGE: Adding WDFS_NETRDR_FOUND property. Its value is ‘C:\WINDOWS\System32\WDFSConnectNetRdr2017.dll_’.
MSI (s) (88:78) [05:47:48:575]: Note: 1: 1322 2:
MSI (s) (88:78) [05:47:48:606]: PROPERTY CHANGE: Adding WIN10_FOUND property. Its value is ‘C:\WINDOWS\SysWOW64\advapi32.dll’.
MSI (s) (88:78) [05:47:48:607]: Note: 1: 1322 2:
MSI (s) (88:78) [05:47:48:609]: PROPERTY CHANGE: Adding NETFRAMEWORK45 property. Its value is ‘#528040’.
MSI (s) (88:78) [05:47:48:610]: Doing action: LaunchConditions
MSI (s) (88:78) [05:47:48:610]: Note: 1: 2205 2: 3: ActionText
Action ended 05:47:48: AppSearch. Return value 1.
Action start 05:47:48: LaunchConditions.
MSI (s) (88:78) [05:47:48:613]: Note: 1: 2205 2: 3: Error
MSI (s) (88:78) [05:47:48:613]: Note: 1: 2228 2: 3: Error 4: SELECT Message FROM Error WHERE Error = 1709
MSI (s) (88:78) [05:47:48:613]: Product: WD Desktop App 2.1.0.311 (x64) – Restart computer is required for this installation to continue.
Action ended 05:47:48: LaunchConditions. Return value 3.
Action ended 05:47:48: INSTALL. Return value 3.
Property(S): UpgradeCode = {DA19C04B-8818-4CCE-9E71-934AC36D5F07}
Property(S): WDFS_DRIVER_FOUND = C:\WINDOWS\System32\drivers\wdfsconnect2017.sys_
Property(S): WDFS_NETRDR_FOUND = C:\WINDOWS\System32\WDFSConnectNetRdr2017.dll_
Property(S): WIN10_FOUND = C:\WINDOWS\SysWOW64\advapi32.dll
Property(S): NETFRAMEWORK45 = #528040
Property(S): INSTALLDIR = C:\Program Files\WD Desktop App
Property(S): FontsFolder = C:\WINDOWS\Fonts
Property(S): ProgramFiles64Folder = C:\Program Files
Property(S): VersionNT = 603
Property(S): ALLUSERS = 1
Property(S): PRODUCTNAME = KDDWDFS
Property(S): WDFSMODULESTOINSTALL = 196611
Property(S): Manufacturer = Western Digital Corporation
Property(S): ProductCode = {CA7F7232-526E-41BD-971A-47BE28C18516}
Property(S): ProductLanguage = 1033
Property(S): ProductName = WD Desktop App 2.1.0.311 (x64)
Property(S): ProductVersion = 2.1.0.311
Property(S): MSIRESTARTMANAGERCONTROL = Disable
Property(S): MSIDISABLERMRESTART = 0
Property(S): MSIUSEREALADMINDETECTION = 1
Property(S): SecureCustomProperties = DRIVER_FIX_FOUND;NETFRAMEWORK45;PREVIOUSFOUND;WDFS_DRIVER_FOUND;WDFS_MNTNTF_FOUND;WDFS_NETRDR_FOUND;WDFSCONNECT_DRIVER;WIN10_FOUND;WIX_DOWNGRADE_DETECTED;WIX_UPGRADE_DETECTED
Property(S): MsiLogFileLocation = C:\Users\MURATL~1\AppData\Local\Temp\WD_Desktop_App_2.1.0.311_20200513054742_002_KDA_Installer.msi.log
Property(S): PackageCode = {DDB8A7B5-C10C-46D2-A040-830A1A96D122}
Property(S): ProductState = -1
Property(S): PackagecodeChanging = 1
Property(S): ARPSYSTEMCOMPONENT = 1
Property(S): MSIFASTINSTALL = 7
Property(S): MSIUNINSTALLSUPERSEDEDCOMPONENTS = 1
Property(S): NORMALINSTALL = 0
Property(S): REBOOT = ReallySuppress
Property(S): CURRENTDIRECTORY = C:\Users\Murat LOKMANOĞLU\AppData\Local\Temp\WDDiscoveryInstaller\WD_Discovery_637249456103678672
Property(S): CLIENTUILEVEL = 3
Property(S): MSICLIENTUSESEXTERNALUI = 1
Property(S): CLIENTPROCESSID = 13908
Property(S): MsiSystemRebootPending = 1
Property(S): VersionDatabase = 500
Property(S): VersionMsi = 5.00
Property(S): VersionNT64 = 603
Property(S): WindowsBuild = 9600
Property(S): ServicePackLevel = 0
Property(S): ServicePackLevelMinor = 0
Property(S): MsiNTProductType = 1
Property(S): MsiNTSuitePersonal = 1
Property(S): WindowsFolder = C:\WINDOWS
Property(S): WindowsVolume = C:
Property(S): System64Folder = C:\WINDOWS\system32
Property(S): SystemFolder = C:\WINDOWS\SysWOW64
Property(S): RemoteAdminTS = 1
Property(S): TempFolder = C:\Users\MURATL~1\AppData\Local\Temp
Property(S): ProgramFilesFolder = C:\Program Files (x86)
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files
Property(S): CommonFiles64Folder = C:\Program Files\Common Files
Property(S): AppDataFolder = C:\Users\Murat LOKMANOĞLU\AppData\Roaming
Property(S): FavoritesFolder = C:\Users\Murat LOKMANOĞLU\Favorites
Property(S): NetHoodFolder = C:\Users\Murat LOKMANOĞLU\AppData\Roaming\Microsoft\Windows\Network Shortcuts
Property(S): PersonalFolder = C:\Users\Murat LOKMANOĞLU\Documents
Property(S): PrintHoodFolder = C:\Users\Murat LOKMANOĞLU\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
Property(S): RecentFolder = C:\Users\Murat LOKMANOĞLU\AppData\Roaming\Microsoft\Windows\Recent
Property(S): SendToFolder = C:\Users\Murat LOKMANOĞLU\AppData\Roaming\Microsoft\Windows\SendTo
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates
Property(S): CommonAppDataFolder = C:\ProgramData
Property(S): LocalAppDataFolder = C:\Users\Murat LOKMANOĞLU\AppData\Local
Property(S): MyPicturesFolder = C:\Users\Murat LOKMANOĞLU\Pictures
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu
Property(S): DesktopFolder = C:\Users\Public\Desktop
Property(S): GPTSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): ShellAdvtSupport = 1
Property(S): MsiAMD64 = 6
Property(S): Msix64 = 6
Property(S): Intel = 6
Property(S): PhysicalMemory = 16267
Property(S): VirtualMemory = 14022
Property(S): AdminUser = 1
Property(S): MsiTrueAdminUser = 1
Property(S): LogonUser = Murat LOKMANOĞLU
Property(S): UserSID = S-1-5-21-1446098803-4094180331-2782602216-1001
Property(S): UserLanguageID = 1055
Property(S): ComputerName = DESKTOP-UT67UQS
Property(S): SystemLanguageID = 1055
Property(S): ScreenX = 1024
Property(S): ScreenY = 768
Property(S): CaptionHeight = 23
Property(S): BorderTop = 1
Property(S): BorderSide = 1
Property(S): TextHeight = 16
Property(S): TextInternalLeading = 3
Property(S): ColorBits = 32
Property(S): TTCSupport = 1
Property(S): Time = 05:47:48
Property(S): Date = 13.05.2020
Property(S): MsiNetAssemblySupport = 4.8.3752.0
Property(S): MsiWin32AssemblySupport = 6.3.18362.719
Property(S): RedirectedDllSupport = 2
Property(S): MsiRunningElevated = 1
Property(S): Privileged = 1
Property(S): USERNAME = Windows Kullanıcısı
Property(S): DATABASE = C:\WINDOWS\Installer\5090e99.msi
Property(S): OriginalDatabase = C:\ProgramData\Package Cache{CA7F7232-526E-41BD-971A-47BE28C18516}v2.1.0.311\KDA_Installer.msi
Property(S): UILevel = 2
Property(S): MsiUISourceResOnly = 1
Property(S): ACTION = INSTALL
MSI (s) (88:78) [05:47:48:651]: Note: 1: 1708
MSI (s) (88:78) [05:47:48:651]: Note: 1: 2205 2: 3: Error
MSI (s) (88:78) [05:47:48:651]: Note: 1: 2228 2: 3: Error 4: SELECT Message FROM Error WHERE Error = 1708
MSI (s) (88:78) [05:47:48:651]: Note: 1: 2228 2: 3: Error 4: SELECT Message FROM Error WHERE Error = 1709
MSI (s) (88:78) [05:47:48:651]: Product: WD Desktop App 2.1.0.311 (x64) – Installation failed.
MSI (s) (88:78) [05:47:48:651]: Windows Installer ürünü yükledi. Ürün Adı: WD Desktop App 2.1.0.311 (x64). Ürün Sürümü: 2.1.0.311. Ürün Dili: 1033. Üretici: Western Digital Corporation. Yükleme başarı veya hata durumu: 1603.
MSI (s) (88:78) [05:47:48:658]: Deferring clean up of packages/files, if any exist
MSI (s) (88:78) [05:47:48:658]: MainEngineThread is returning 1603
MSI (s) (88:00) [05:47:48:658]: No System Restore sequence number for this installation.
=== Logging stopped: 13.05.2020 05:47:48 ===
MSI (s) (88:00) [05:47:48:662]: User policy value ‘DisableRollback’ is 0
MSI (s) (88:00) [05:47:48:663]: Machine policy value ‘DisableRollback’ is 0
MSI (s) (88:00) [05:47:48:663]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (88:00) [05:47:48:663]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (88:00) [05:47:48:664]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (88:00) [05:47:48:664]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (54:68) [05:47:48:667]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (54:68) [05:47:48:667]: MainEngineThread is returning 1603
=== Verbose logging stopped: 13.05.2020 05:47:48 ===
{“msgid”:“installError”,“portalId”:“c5788f38-bc29-4739-8b6c-9d4b43296e20”,“product”:“WD Desktop App”,“version”:“2.1.0.311”,“time”:“2020-05-13T02:47:48Z”,“message”:“MSI (s) (88:78) [05:47:48:658]: MainEngineThread is returning 1603”}
