My WD Discovery used to show all of my WD drives. 2 WD Blacks, a WD Blue and My Cloud Home. Ever since the last software update, WD Discovery only shows the My Cloud Home and not the other drives. Any one else having this issue? Just curious. I’m on Windows 10.
Hi thomp,
You can refer the link given below for such issue.
Moreover, you should try contacting WD’s Technical Support about the same concern.
The link below will allow you to call support.
