My Passport Ultra will not start, I receive the following message
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: wdbackupsettings.exe
Problem Signature 02: 1.0.5953.19621
Problem Signature 03: 57167eca
Problem Signature 04: System.Runtime.Serialization
Problem Signature 05: 4.0.30319.34234
Problem Signature 06: 53cf4754
Problem Signature 07: 1464
Problem Signature 08: 2a
Problem Signature 09: System.Xml.XmlException
OS Version: 6.1.7601.2.1.0.256.4
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Hello marelle,
Please test your drive using Windows Data life diagnostic:
Thanks, just completed. The report from the quick test was “pass”
Western Digital Logo
Test Option: QUICK TEST
Model Number: WD My Passport 0827
Unit Serial Number: WXA1A45H1E2X
Firmware Number: 1012
Capacity: 2000.37 GB
SMART Status: PASS
Test Result: PASS
Test Time: 17:54:06, October 19, 2017
Hello marelle,
Your drive seems to have pass all the test results so you shouldn’t face any issue using the drive. Can you please elaborate your issue?
As I put in my original post, it does not work.
I get the following message:
WD Backup has stopped working.
Locale ID: 1033
Hello marelle,
Maybe you should try contacting WD’s Technical Support about this.
The link below will allow you to call support.
Did you ever get this issue resolved? I am facing the same problem and having difficulty finding a solution.
Thanks,
Daniel
No, WD support could not offer a solution and I could not get refund from the place I purchased. I have to throw it away.
Oh no! Thanks for the reply. I am using the Windows backup program to backup to the WD Drive, so not having to throw it away yet, but cannot manage it like I could when WD Backup actually worked.
Regards
