I’ve had WD Backup installed and running for years now. I last performed a backup April 5th. Today I went to run a backup and it will not open. The Icon is in the taskbar, but if I try and launch the backup nothing happens. If I go into the Start->ALl Programs… and launch WD Backup I get a Windows error popup reporting “WD Backup has stopped working”
I am running Windows 7 x64.
I’ve checked my event viewer and this is what I see:
Application Error
Faulting application name: WDBackupSettings.exe, version: 1.0.6598.18395, time stamp: 0x5a68ccb7
Faulting module name: KERNELBASE.dll, version: 6.1.7601.24094, time stamp: 0x5abee073
Exception code: 0xe0434352
Fault offset: 0x0000c54f
Faulting process id: 0x162c
Faulting application start time: 0x01d3d6ac691e5fc4
Faulting application path: C:\Program Files (x86)\Western Digital\WD App Manager\Plugins\WD Backup\App\WDBackupSettings.exe
Faulting module path: C:\Windows\syswow64\KERNELBASE.dll
Report Id: a87c2516-429f-11e8-a1ce-005056c00008
.NET Runtime
Application: WDBackupSettings.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.Xml.XmlException
at WesternDigital.Backup.BackupPlanService.LoadSchedule(System.String)
at WesternDigital.BackupSettings.ViewModels.ManageBackupTarget.b__b()
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at MS.Internal.CulturePreservingExecutionContext.Run(MS.Internal.CulturePreservingExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
at System.Windows.Threading.Dispatcher.PushFrame(System.Windows.Threading.DispatcherFrame)
at System.Windows.Application.RunDispatcher(System.Object)
at System.Windows.Application.RunInternal(System.Windows.Window)
at System.Windows.Application.Run(System.Windows.Window)
at WesternDigital.BackupSettings.App.Main()
I tried uninstalling and reinstalling the software and it made no difference.
Anyone have any ideas.
I did tried contacting WD Support, filled out their online contact form and submitted it only to have that crash and report some error. Just one of those days I guess.
Thank you in advance for your help.
