I’m search type-number of akku-cable for mybook wd 5000 h 1 u. Where can help me
See http://support.moonpoint.com/hardware/power/adapters/WDPS034RNN.php
Replacement Power Supply for My Book ( WDPS034RNN ):
http://www.wdc.com/en/products/accessories.asp?ProdID=247
http://web.archive.org/web/20080723171430/http:// www.wdc.com/en/products/accessories.asp?ProdID=247
I have the power adapter, but I’m looking for a replacement USB cable for the wd 5000 h1u. What should I be looking for specifically in size e.g., 5pin, etc.? I appreciate any help you could shed. Thanks!
sf
You need a USB A to Mini B cable for the drive. You can purchase them on the online store or through tech support.
http://support.wdc.com/contact/index.asp?lang=en
