My Passport will only allow files to be read for a few seconds after it loads on my Mac. After that, everything comes up with an error code. The files are there, they just won’t read after the first few seconds. No idea why this changed. Drive is 3 months old.
Hi Shwifty1,
Maybe you should try contacting WD’s Technical Support about this.
The link below will allow you to call support if you are having trouble with the form.
