Warranty dates
Good morning.
I am Oscar Diamante, argentinian. RMA 88564198.
I sent my SSD on June 25, to the WD warehouse in my country and it was just registered on July 5.
Even today, July 28, more than a month, I don’t have the product, and from WD they don’t give me a solution other than to keep waiting for it.
I need my PC to work, and I didn’t think the warranty would take that long. I will have to buy a new drive from another brand if I do not receive the SSD shortly.
I ask please, if you cannot send the same disc, another type of solution to my problem.
Hi @oscardiamante,
Please refer below link to contact the respective support team to check your RMA status:
https://support-en.wd.com/app/utils/login_form
Hello.
The process continues without modifications, WD does not solve my problem. What other type of solution can you provide?
