Undo on SanDisk - Switch vault USB?
Is there such a thing as an undo command for use in the Switch Vault? I have found the screen is not properly touch screen interactive, so mistakes do happen which is bad if there is no undo command.
None that I am aware of.  Hopefully you have backups.
Thanks: I’ll accept the risks, but if an undo mechanism could be installed I would welcome that!
