I want to reverse the auto unlock feature I’ve previously set-up. I want the password to always be needed. .
I am given no option when the page pops up when I click on Unlocker. I tried to run WDSecuritySetup, but the only option is Uninstall. Tried that anyway, but when re-installed there was no option to undo auto-unlock.
If you want to change WD Unlocker security options you cannot do this from WD Unlocker itself. You have to install a separate program called “WD Security” which you can download from the WD Support site. Once installed you can use WD Security to change and/or remove your password. Removing the password allows you to access the drive directly. Here’s a link to WD Support: WD Security Download
