I have just purchased a My Passport 4Tb drive. Installed the WD software and performed my first backup, which completed successfully. However, I cannot disconnect the drive from my laptop. I click the Safely Remove Hardware and Eject Media icon in the system tray and select Eject My Passport 2627. The My Passport LED blinks and a dialog box appears with the message “Problem Ejecting USB Mass Storage Device. "This device is currently in use. Close any programs or windows that might be using the device and then try again”. Closed all the windows and tried again. Same dialog box.
I started a chat with WD and the operative suggested using the WD Drive Utilities software to eject the drive. Tried this, but got the same (or similar) dialog box.
In Device Manager > Disk Drives > WD My Passport > (right click) > Properties > Policies the default selection is Quick Removal under which it says “…you can disconnect the device safely without using the Safely Remove Hardware notification icon”. When I told the WD operative he said this is not recommended!.
The only solution he could come up with was to close down my laptop and then remove the drive! Not very practical or convenient if I have to do that every time!
Has anyone else had this problem and is there a solution?
