I was trying to format my new HDD (My Passport 4TB) to exFAT so that I can use it on MAC and Windows. I was following the WD Comunity instructions, but when I opened the New Simple Volume Wizard on my Windows 10, it would not give me an option to select exFAT in the section File System.
For a hard drive to be able to be read and written to in both a PC and Mac computer, it must be formatted to ExFAT or FAT32 file format. FAT32 has several limitations, including a 4 GB per-file limit. This is a file system limitation that affects both Mac’s and PC’s, and the only workaround is to format the drive to exFAT.
For more information you can follow the link-
