I have been unable to access my Sandisk flash memory stick. I have tried repairing and cleaning programmes. I have tried formatting it, but after a while I get an error message saying - unable to complete formatting.
Can anyone help or is th stick just fit for the bin??
Try to use low level format tool, there are a lot of them free just google it, if still no success, it means that the circuit of the usb has the problem already, you can contact your manufacturer and ask for replacement if it’s under warranty.
You meant that the memory stick can be recognized by your PC by you couldn’t access your files on it? Here is the solution.
Retrieve your photos and videos off it with memory stick data recovery software,recommended one is Tenorshare Data Recovery (simply because i was using it and it worked).
2.Format it with memory stick formatting tool like Memory Stick Formatter,Any Drive Formatter.
