Unable to clone
Hello. I have an Ibuypower bb930 gaming pc. It came default with a wd green ssd that boots windows 10. It also came with a wd blue 1tb. I went ahead and added a wd blue 3tb, samsung 850 evo 500gb, and an external wd 4 tb for backups. today i got my samsung 960 evo m.2 250gb. my mobo is asus prime h270 plus. it comes with two m.2 slots. i installed the m.2 in to slot 1 (closest to cpu as per asus). went ahead and created the simple drive and it gave it letter H. I also double checked in manager and the m.2 shows up under disk drives. So i installed the drivers for the m.2 from samsung and restarted. i went ahead and installed samsung migration software as well as wd acronis. i used the samsung migration and it gave me the cloning error. i unchecked page file and got rid of restore. still error. so i checked disk management again and for some reason i had to create a simple drive again for the m.2…so i did…H again. used acronis and it gives me the error that it will do clone sector by sector. so i cancelled it to make sure i can do that?
does the following matter…could it be the error:
my c drive the wd ssd 120 gb boot drive says it has a 100mb efi system partition, 500mb recovery partition and the 111.9gb primary partition.
could the 100 efi be the error causing all this?
I also ran chdsk on c and it is healthy with no errors. For some reason the efi system partition has lines going across at a 45 degrees.
Any advice will be greatly appreciated. thx.
Hi Legendary70,
Maybe you should try contacting WD’s Technical Support about this.
The link below will allow you to call support if you are having trouble with the form.
