Ultra Fit 128GB makes my Logitech mouse cursor frozen
I bought Ultra Fit 128GB and I noticed that my mouse cursor sometimes frozen for around half second and move quickly.
It annoying me a lot. I need to do very precison mouse control for CAD drawing.
I am using Logitec mouse with USB nano receiver. It happened again even if I was using wired mouse.
Is there any recommendation?
i think i have seen other people report similar issues with logitech mice and keyboards when there is a USB 3.0 device lugged into adjacent ports. You can try moving the mouse receiver to a different port or use a USB extension cable and plug the mouse receiver into that and the issue should go away.
