Trial on encryption software is up
Hi
The trial on the encryption software for my hard drive has expired. It now asks to activate it with a code, but I don’t have one. I talked to someone on the phone about this and they said to go to www.memeo.com. What exactly will that site do so I can see my files? I can’t see them now because they are in the software. Is there another way other than that site that I can view my files with? I really want to know if my pictures are still in the drive.
Thanks,
Lisa
Memeo is not an encryption software.  Are you sure you’re not talking about WDSync?  Since there’s been no replies, maybe you should try contacting WD’s Technical Support about this. You can do so either by phone or email.
http://support.wdc.com/contact/index.asp?lang=en
