HDD WD Elements SE 750GB NTFS USB 3.0 (WDBPCK7500ABK-EESN), PС Windows 7x32, WD TV Live SMP.
When connecting to the PC disk drive lamp flashes rapidly. The disc can be heard the quiet beeps.
The disk is not detected in the PC. I disconnect the drive from the PC.
Is connected to the WD TV Live - the disc properly defined.
Eject a disc from the WD TV Live and then re-connect to your PC. It is well defined.
Six months after buying the drive worked fine,
but last month it happens a second time.
Media Library in the WD TV Live is always off.
I’ve always deleted from the disk folder wd_tv.
The WD TV Live SMP has a bad controller rear USB port.
Can this be the reason?
http://community.wdc.com/t5/WD-TV-Live-Streaming-Discussions/Intention-to-finalize-a-rear-USB-port-issue-drives-USB-3-0/td-p/392589
CrystalDiskInfo 4.2.0 (C) 2008-2012 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 7 Ultimate Edition SP1 [6.1 Build 7601] (x86)
Date : 2012/08/06 18:44:42
WDC WD7500KMVW-11ZSMS5
Enclosure : WD Elements 1042 USB Device (V=1058, P=1042, sa1)
Model : WDC WD7500KMVW-11ZSMS5
Firmware : 01.01A01
Serial Number : WD-WXC1A7******
Disk Size : 750.1 GB (8.4/137.4/750.1)
Buffer Size : 8192 KB
Queue Depth : 32
# of Sectors : 1465149168
Rotation Rate : 5200 RPM
Interface : USB (Serial ATA)
Major Version : ATA8-ACS
Minor Version : ----
Transfer Mode : SATA/300
Power On Hours : 746 hours
Power On Count : 367 count
Temparature : 27 C (80 F)
Health Status : Good
Features : S.M.A.R.T., APM, 48bit LBA, NCQ
APM Level : 0080h [ON]
AAM Level : ----
– S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 200 200 _51 000000000000 Read Error Rate
03 157 147 _21 0000000013F4 Spin-Up Time
04 100 100 __0 00000000028B Start/Stop Count
05 200 200 140 000000000000 Reallocated Sectors Count
07 100 253 __0 000000000000 Seek Error Rate
09 _99 _99 __0 0000000002EA Power-On Hours
0A 100 100 __0 000000000000 Spin Retry Count
0B 100 100 __0 000000000000 Recalibration Retries
0C 100 100 __0 00000000016F Power Cycle Count
C0 200 200 __0 00000000006F Power-off Retract Count
C1 199 199 __0 000000000DE7 Load/Unload Cycle Count
C2 123 109 __0 00000000001B Temperature
C4 200 200 __0 000000000000 Reallocation Event Count
C5 200 200 __0 000000000000 Current Pending Sector Count
C6 100 253 __0 000000000000 Uncorrectable Sector Count
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
C8 100 253 __0 000000000000 Write Error Rate
