SSD Green Not Showing Up
I bought SSD Green 240Gb and I’m trying to install It. I tried connecting It to every SATA connector and it’s still not showing up in BIOS or Windows. I have AHCI turned on. Do I need to turn something else on BIOS?
Even i have the same problem help me with this
How are you looking at it in Windows? Disk Management can’t see it? If you haven’t tried Disk Management, Windows Search for it and see if it’s visible. Or register your product and open a support case.
Even it’s not visible there I looked up in BIOS too it’s not showing anything
What connector are you using?
It’s laptops SATA
Try registering your product and opening a support case. They helped me. Here’s the link:
https://support.wdc.com/support/productregistration.aspx?lang=en
