Hello Community,
I built a new PC last January 2022, and i bought a Samsung 990pro SSD, degradation was bad so i change to a SN850x 2TB because of the good reviews however i have noticed something since i started to use it.
I’m using Windows 11 and the firmware is up to date.
Only the first boot is super fast (when the machine is cold).
After a minutes of use subsequent boots are not that fast, i mean they are fast but slower than that first cold boot.
Is that normal? i assume not, and i assume that’s thermal throttling isnt it? or Is the nvme faulty?
I have a 13990k cpu (i’m not overclocking), Rog Maximus Z790 Hero mobo, i installed the stick on slot 1 (the one closest to the CPU).
Thanks for your replies.
