I have accidentally deleted a share on my WD EX2 Ultra, it had 4TB of content, is there anyway of recovering it? Please help
Hi @KVD ,
Have you opened a Support Case? If not opened, for more information, please contact the WD Technical Support team for the best assistance and troubleshooting:
To prevent overwriting the data, avoid using the NAS then the easiest option would be to check the Recycle Bin functionality. WD My Cloud devices offer a recycle bin feature for shares. It might be called something like “Recycle bin - Volume_X”. Also, you may need to remove the drives from the NAS and connect them to a computer using a SATA-to-USB adapter or directly via SATA if using recovery software.
