Set up help
Can I back up more than one computer on one WD Passport device?  I’ve tried it by loading the software on both computers but the device seems to connect with only one of them.  thanks
You’ll only be able to back up the computer that the MyPassport is physically connected to (presuming you’re using WD Smartware or WD Backup). So yes you can do multiple computers as “snapshot backups”, but only one at a time.
