Does Sandisk have utility tools for secure data wiping for USB drives? Am unsure if Eraser (open source data removal tool) would be adequate for secure data wiping a USB portable drive omegle.
Thanks
Deleting all the files and folders will prevent the encrypted files from ever being recovered. Nothing special needed.
In theory sandisk dashboard should allow for a secure erase
Eraser wipes free space, but if paranoid you have to know it won’t wipe spare/marked bad sectors. If you aren’t dealing with state secrets, honestly this doesn’t matter. A single over write over anything over a drive, no one is going to be able to recover it, and even highly motivated agencies unlikely, the idea one could recover data off over written drives was always just a bit theoretical.
#SanDiskUserRewards
On Linux you can use:
dd if=/dev/random of=/dev/YOUR_USB_DRIVE
On Windows free utility is part of CCleaner, you can even erase only free space.
No, SanDisk does not offer utility tools specifically for securely wiping USB flash drives.
The SanDisk Dashboard tool includes features such as Secure Erase and Sanitize, but these are intended for internal and external SSDs, not for standard USB flash drives.
Reference: Steps to Secure Erase and Sanitize a Drive with SANDISK Dashboard | Sandisk
Alternative methods to clean and erase a USB flash drive include:
- Full format using your operating system (for Windows, uncheck Quick Format). This erases data more thoroughly than a quick format.
- Third-party disk-wiping tools, which can overwrite the entire drive and make previously stored data irrecoverable.
- Use the Windows built-in diskpart utility to wipe your USB drive.
( Further reading: How to Clear a USB Drive Completely with/without Formatting )
