Keep getting error message “must be accessed from external sandisk device”. When I try to install on disk I get picture of vault but nothing for set up of password.
once you extract the .exe file from the .zip you ahve to copy the .exe or .dmg if MAC to the flash drive and run it from there. if the install files is not on the flash drive it will not run and you will get that error message.
