I damaged the Micro USB port from inside by pressing the USB cable very strong . I can’t see any solution other that weld a new USB port.
My question is Can I replace that weak design Micro USB port with the regular Mini USB port?
will it worked that way?
I can see that both USB ports have the same endings (five lines mini bars)
I just want to get my data back :cry:
