Sansa going the way of iRiver?
Touché !
Perhaps, but I don’t appreciate it when snot-nosed little trolls like aircraftkiller start spouting off
because they can’t handle constructive criticism.
@tmarkoski wrote:
Touché !
Not to mention that MTP does indeed ■■■■.  Good MSC mode support is one of the main reasons I bought the Fuze.
I have this little theory: MTP works fine for me. I have never had issues transferring any files except those that I moved accidentally so they weren’t in the proper location during the file transfer. Album art transfers fine. In fact, the only issue I have with MTP is that I have to use WMP11 because WinAmp doesn’t work correctly with MTP transfers. So if I, and a lot of other people, can use MTP without problems, I’d think the issue is with you and what you’ve done to your computer. ■■■■ it up and stop crying about it.
I didn’t say it didn’t work on my computer, I said it sucked.  Much like you, you arrogant jerk.  If you want to use a proprietary protocol that severly limits your choices, then by all means use it.  If you love DRM, then great, more power to you.
If on the other hand you value choice, as in “I’ll use whatever OS or tools I like”, then MSC is the only choice.
I suppose all the Linux and Mac users should ■■■■ it up and go MTP?
Yeah, they should ■■■■ it. Macs are garbage, Linux can run Windows in a shell, and I don’t use DRM music. Oh no, I can’t transfer easily via drag and drop… better go complain on an internet forum gogogogogo!
@skinjob wrote:
[snip]
Skinjob, I agree with your point (and may share your system setup), but responding to the troll is bad enough; you needn’t feed him leading questions. You and this forum deserve a better level of discourse.
This thread is getting off track and personal attacks will not be tolerated so I am locking this thread. If the personal attacks continue in other threads the offending users will earn themselves a little vacation.
Forum Admin
